hi everyone
need a basemap for a b16a with
car type civic 1995 4 door
b16a swap
2 1/2 inch exhaust system
garrett nissan rb25 turbo open at 1 bar
OMNI 3 bar B series map sensor
AEM fuel rail and regilator set at 60 psi
1000cc precision injectors
Skunk2 66mm Alpha Throttle Body
BLOX POWER INTAKE MANIFOLD up to 72mm
Golden Eagle Cam Gear Gears
Wiseco Forged Pistons Eagle Rods 10.75:1 81mm
b18c type R camshafts and lifters
ARP main and head studs
AEM UEGO Wideband O2 Air/Fuel Ratio Gauge and the Bosch 4.2LSU sensor
cometic std size and bore head gasket
ACL Race BEARINGS Kit
Vtec Gates Racing Belt Timing Kit
5 bar fuel pump
if anyone can help it would be great
thanx
b16a turbo 1000cc injectors
abdullahjamo
abdullahjamo
Re: b16a turbo 1000cc injectors
my problem is the car wont start with the default timing and latency settings for the injectors. even when I have them set to 1000cc
