Page 1 of 3
yes another need help thread......
Posted: Thu Jun 27, 2013 8:49 pm
by Lazysk8r2
Car: 2000 Civic Si
ECU: p28
OBD2B
Not syncing. Has power and the red light flashes.
While wiring it up there was no wire in A22 so added one. Also tried A21 and got a code 4. Anyways im attaching an image of how i wired it up. Is this the right way? So far this has been a huge headache for 6 wires lol.
Re: yes another need help thread......
Posted: Fri Jun 28, 2013 9:20 am
Post your calibration. Also if you have the wires connected to the distributor then it will not work as those wires need to tap into the harness side of the plug, not the distributor. A23 and A25 cannot be disconnected, they should be joined at the ECU wires, but not cut.
Posted: Fri Jun 28, 2013 10:03 am
by Lazysk8r2
I cut them, im gunna try putting them back together and see if that fixes it. And i have the wires going into the harness side, but that didnt make any sense to me so i made the diagram based on what i was thinking would work. Because i dont see how the cpr gets the signal from the dizzy so know when to fire. Ill have to try this on monday when im back at work where my car and tuning laptop are, unless i can get someone to let me in on sunday.
Ill you posted and updating my diagram so you can use it if needed to explain how to wire.
Thanks,
Posted: Mon Jul 01, 2013 11:14 am
by Lazysk8r2
Connected 23 and 25 back and made sure all the wires are ran right. Still no sync or start. Heres my calibration.
i checked continuity and it was good.
Posted: Mon Jul 01, 2013 11:51 am
Make a new diagram showing exactly how you have everything connected. Also check all 3 boxes for the CPR in the calibration. Have you verified that your ECU has component Q37 installed?
Posted: Mon Jul 01, 2013 12:41 pm
by Lazysk8r2
Yeah i opened it up, has Q37. Here is a new diagram. Also tried with all three boxes checked. I cant figure out what im missing.
Posted: Mon Jul 01, 2013 1:23 pm
Post a picture of how you have this wired at the ECU plugs please.
Posted: Mon Jul 01, 2013 5:52 pm
by Lazysk8r2
Heres how its wired. A22 didnt have a wire so i added that blue one, the others i cut and wired in.
Posted: Mon Jul 01, 2013 5:56 pm
by Lazysk8r2
more.
Posted: Tue Jul 02, 2013 10:36 am
Try depinning A21 and move the pin from A22 to A21. Leave the pin that came from A21 disconnected.
Posted: Fri Jul 05, 2013 11:25 am
by Lazysk8r2
After swapping out my hacked conversion harness and redoing all the wires and finding a blown fuse, it started working. Now the tachometer isnt working. Any ideas?
Posted: Sat Jul 06, 2013 2:12 pm
by Lazysk8r2
the hondata shows my rpm just do not have it at the cluster.
Posted: Mon Jul 08, 2013 9:56 am
Make sure the the tach output from the CPR is wired into the tach signal wire in the harness that goes to the cluster.
99-00 Civic SI's are different than most Hondas in that the tach signal is not from the distributor but from the ECU itself.
Posted: Tue Jul 09, 2013 9:09 am
by Lazysk8r2
Got everything working, wired tach into A19 obd2b. Now i just have to figure out why sometimes it drops while driving randomly. Going to try to get a datalog.
Posted: Wed Jul 10, 2013 8:17 am
by Lazysk8r2
I got three datalogs but didnt see anything out of the ordinary in them but in all three the car was dropping out for half a second ill post them anyways. Could it be bad coil packs.
