Currently I have my two step hooked up to my air conditioning pin and I have it grounded to a little switch that I made. When the switch is grounded my 2step activates but when its not grounded it does not activate. AND I also have my high and low boost switch controlled by the same AC pin by the exact same switch but "inverted" so that when I turn my 2-step off, my low boost table activates. NOW my question is, can I continue to do this without damaging some kind of electrical component in the ecu? Can I have 2 inputs or even more than 2 inputs running on the same B5 AC switch wire? Or is 2 my limit?
thanks
Albert
Quick Question !!
Re: Quick Question !!
This will not cause any damage.
