Dattaloging stops recording, car wont start
Posted: Tue Jun 18, 2013 2:08 pm
My kpro stops dataloging, i just change spark plugs and i when for a run and now car wont start, i tried to conect my laptot and nothing
Hondata User Forum
https://www.hondata.com/forum/
They are the oemKairu2010 wrote:did you make sure they were the right spark plugs.
03 acura rsx rebhard turbo kit,kpro 3, i just install the hondaa map sensor 4 bar and ngk ifr7g-11ks 7746 laser iridium, same spark plug from last time, i when for a run and stops recording like about 6000 rpms, i disconnect the usb from my laptot and connected againg and started recorded againg and stops, i park the car, turn off, i check what i recorded, after a minute i tried to start the car and nothing, is like it want to start but dies, now i tried to conect the laptop and wont connect to kpro.Felipito wrote:They are the oemKairu2010 wrote:did you make sure they were the right spark plugs.
Kpro v3. 12106, k manager 3.2.4Spunkster wrote:What is the serial number of the K-Pro board inside the ECU? From Help, About, what version of software are you using?
I just update my kmanager, upload the rebhard cal. Spark plug are new and now i am having a p0500 and p1106 code, now car start but when a press the gas pedal it died.Felipito wrote:Kpro v3. 12106, k manager 3.2.4Spunkster wrote:What is the serial number of the K-Pro board inside the ECU? From Help, About, what version of software are you using?
I replace the hondata map sensor for the oem and now is fine. Thanks for all your help, i really apreciateFelipito wrote:I just update my kmanager, upload the rebhard cal. Spark plug are new and now i am having a p0500 and p1106 code, now car start but when a press the gas pedal it died.Felipito wrote:Kpro v3. 12106, k manager 3.2.4Spunkster wrote:What is the serial number of the K-Pro board inside the ECU? From Help, About, what version of software are you using?
