Hi guys , I<m tuning a 2005 S2000 and I have retarded timing on my log but no knock count ? is there something Im doing wrong ?
2005 S2000 no knock count but retard timing
julienperformance
Re: 2005 S2000 no knock count but retard timing
Yes, it is normal. Read the help file about the way Honda knock logic works. You can have knock retard without knock, and also knock without knock retard.
julienperformance
Ok thanks , now is this normal that when Im changing the size of the injectors all the values in the fuel map are not changing ? Also even after changing the injectors size I have to add at least 20% of fuel to have the car running ?
Yes, that is normal as well. If you have to add 20% fuel after an injector change then it could be the dead times are too low.
