PRC KPRO + Traction Control
dantok
Post by dantok »
Hey Guys,
I have the TC Unit, just wanted to make sure it will work with the PRC KPRO V3 ecu that i have.
Please advise :)
Re: PRC KPRO + Traction Control
The PRC does not support the ELD input, which is the preferred TC input.
dantok
Post by dantok »
Yikes.
What are my options here? Am i able to buy a PRB ECU and transfer the traction control unit over?
Or can i use the other output available?
Sorry i`m a little lost, isn't the ELD input the same input for the O2 sensor?
Correction, ELD input does work on a PRC. I tested this on the bench yesterday.
Knox
Post by Knox »
Spunkster wrote:Correction, ELD input does work on a PRC. I tested this on the bench yesterday.
So, prc ecus (also prd ecus) can use the traction control easyly ?
Yes they should work.
