1.5.5 Civic AFM Calibrations Radiator fan issue
Posted: Fri May 31, 2013 5:20 pm
by VitViper
When unchecking 'use second ect sensor to control fans' the fans don't seem to turn on... I'm burping my Si and the ECT is 228* with no fan activity.
Re: 1.5.5 Civic AFM Calibrations Radiator fan issue
Posted: Mon Jun 03, 2013 9:54 am
What year and vehicle and can you post a datalog showing hte problem as well as the calibration?
Posted: Mon Jun 03, 2013 10:04 am
by VitViper
If I must... I do not have the 228 ECT logs as I was not recording when I was burping the system, but here is idle after I had burped the car. Cal is attached as well -- even with the option unchecked the ECU is still using the second ECT sensor to toggle the fans on/off.
2011 Si
