N eed help with this map tuners welcome.
Posted: Tue May 28, 2013 8:40 pm
by jdragon1974
firsttunewithcams051913.skl
3rdgearpull.s3d
Here is my set up:
OK, so kinda new here. this is the mods I have on my current set up
gsr bottom end:
ls crank
eagle ls rods
81.50 pr3 pistons
Race balance on whole rotating assembly
stock 3 layer head gasket
B16a2 head:
blox springs and ti retainers
Blox type C cams
stock valves, new valve guides
itr Intake
omni 68 mm tb
stock gsr injectors
short ram with blox velocity stack
gsr tranny:
exedy stage 1 clutch
exedy 9.5 lb flywheel
also here is my a/f data log from Logworks, since I cant get my hondata to read my MTX-1 its on dropbox, so it has all the info.
https://www.dropbox.com/s/nduhyx5ijep95 ... 051913.skl
https://www.dropbox.com/s/solzu1nj622gk ... arpull.s3d
https://www.dropbox.com/s/mfh72zpfmu5xc ... arpull.log
Re: N eed help with this map tuners welcome.
Posted: Wed May 29, 2013 9:27 pm
by Progress
You need to upgrade your injectors and fuel pump. You need to get TUNED. I think you running close to 12.5:1 with those pistons.
Posted: Wed May 29, 2013 9:37 pm
by Progress
Yea need to upgrade injectors and fuel pump according to you datalog you maxing them out at 5800 rpm. So you have another 3k to go. Upgrade and get it tuned.
Posted: Thu May 30, 2013 1:20 pm
by jdragon1974
Progress wrote:Yea need to upgrade injectors and fuel pump according to you datalog you maxing them out at 5800 rpm. So you have another 3k to go. Upgrade and get it tuned.
3rd gear pull.s3d
I was told at machine shop I would be at 11:6:1
So up grade fuel pump and injectors. so prob rdx injectors will do? I uploaded another data log with my wide band working with hondata, just want to double check. Thannk you for your help.
Posted: Thu May 30, 2013 10:03 pm
by Progress
Use RC 440cc. No you around 12.3:1-12.5:1.
Posted: Thu May 30, 2013 10:04 pm
by Progress
I'll check your log tomorrow, im going to bed now.
Posted: Sat Jun 01, 2013 10:43 pm
by Progress
Last log is blank. Didnt record.
Posted: Tue Jun 18, 2013 1:12 pm
by jdragon1974
Sorry about that. Here you go. Let me know if this looks right.
Posted: Wed Jun 19, 2013 8:08 am
by jdragon1974
TunerFreak89 wrote:
3rdgearpull.s3d
Here is my set up:
gsr bottom end:
ls crank
eagle ls rods
81.50 pr3 pistons
B16a2 head:
Blox type C cams
itr Intake
omni 68 mm tb
stock gsr injectors
gsr tranny:
I couldn't figure how You where unloading in 1st in ALL Blue. Then, I noticed your 1st gear ratio 3.20's, nice figures sir. Great build.
Thanks, still trying to figure how it is 12:3 or 12:5 or what ever was said, could have sworn i was at 11:6:1, but I guess it would explain alot, 93 oct is the best gas I can get, would not mind going e85 if there was more places that had it.
