d16z6 n/a fully build with comp cam 59300 76mm p29 pistons.
Posted: Fri May 17, 2013 11:46 am
by biggied16king
I have a build d16z6 with crower valve train ( flat heads ), comp cam 59300, 76mm p29 pistons, 255walboro fuel pump, dsm 450cc, msd spark plug wires and coil, 0.30 cosmetic head gasket, skunk 2 pro series IM and TB, JG header. I need a good base map until I get it tune. Its running good but its knocking cause its leaning and if anybody can help me out that would be nice. Big thanks!
Re: d16z6 n/a fully build with comp cam 59300 76mm p29 pisto
Posted: Fri May 17, 2013 11:04 pm
by Progress
You cant use DSM injectors on a S300 use RC or ID. What kind of knock do u hear.
Posted: Sun Jun 02, 2013 5:17 pm
by biggied16king
you sure I cant use dsm on a s300? will it only knocks when the motor is hot ( normal temp ) runs good and everything but when your slowly hitting the gas a little bit then you can hear the knock , no knock when WOT. my buddies tell me its a lean knock so I just need a good basemap b4 my tune
Posted: Sun Jun 02, 2013 9:00 pm
by Progress
That what they say.
Posted: Mon Jun 03, 2013 9:51 am
You can use them, but they are not recommended as they are known to be unreliable.
Posted: Tue Jun 11, 2013 7:11 pm
by biggied16king
oh ok thanks then. but do you know where I can get a base map for my set up? it will help me a lot
