ethonal content analyzer
Posted: Mon May 13, 2013 8:32 am
by aceman187443
I'm am getting ready to hook up a zeitronix analyzer on a 93 civic. It is odb1 and has no egr valve so the d12 spot is open on the ecu and labeled as "blank" . Will the ecu read the analyzers output on the d12 wire using my s300 even though it is labeled as "blank"? Thanks a million!
Re: ethonal content analyzer
Posted: Mon May 13, 2013 8:47 am
D12 is the normally unused EGR lift input. To use it you need to add a capacitor for some ECUs.
See
http://www.hondata.com/help/smanager/an ... ghtsub=d12
Posted: Mon May 13, 2013 10:44 am
by aceman187443
I'm am goin to swap a p75 intgera odb1 ecu into it that I found here laying around. Its a odb1. Does a p75 need the mods done too or is it a direct wire?
Posted: Mon May 13, 2013 10:51 am
You will have to click the link above and see if the ECU in question has the components needed, If not, you will have to add them.
Posted: Mon May 13, 2013 12:39 pm
by aceman187443
It seems the p75 does have the resisters and not the cap. Is it common for a ecu to have the resisters but not the cap? I will just install the cap I need and leave the resisters Installed. Then run my 0-5volt Input to the d12 ? I just wanted to verify this was correct because of the resisters I do see much reading about. Thanks again!
Posted: Mon May 13, 2013 2:00 pm
The resistors have nothign to do with D12. Only the capacitor is need is what must be added.
