To HONDATA. 8 injectors
Posted: Thu May 09, 2013 7:32 am
by Progress
Hello. Is there any way i can wire 8 injectors to run s300. Thanks.
Re: To HONDATA. 8 injectors
Posted: Thu May 09, 2013 9:30 am
Not without damaging the ECU. The ECU is designed to only run 4 injectors.
Posted: Thu May 09, 2013 10:33 am
by Progress
What if you change resistors. So 2 injectors get triggered at 1 time
Posted: Thu May 09, 2013 10:50 am
I would not recommend this.
Posted: Thu May 09, 2013 12:17 pm
by Progress
Ok. Any suggestions.
Posted: Thu May 09, 2013 1:19 pm
What size injectors are you using?
Posted: Thu May 09, 2013 3:13 pm
by Progress
2000cc
Posted: Fri May 10, 2013 8:33 am
You can run 8 high impedance injectors for short periods without a problem. At idle the duty cycle is low enough that they will be ok, and as long as the maximum load is limited in time (eg a drag race) the injector driver will not overheat. But then, if you're using 8 x 1000cc+ injectors, you're not going to maintain full throttle for long periods.
