To HONDATA. 8 injectors
Progress
Post by Progress »
Hello. Is there any way i can wire 8 injectors to run s300. Thanks.
tuning upon request
347-989-5028
9.23@167 B18C street/track tuned
HP unknown
Re: To HONDATA. 8 injectors
Not without damaging the ECU. The ECU is designed to only run 4 injectors.
Progress
Post by Progress »
What if you change resistors. So 2 injectors get triggered at 1 time
tuning upon request
347-989-5028
HP unknown
I would not recommend this.
Progress
Post by Progress »
Ok. Any suggestions.
tuning upon request
347-989-5028
HP unknown
What size injectors are you using?
Progress
Post by Progress »
2000cc
tuning upon request
347-989-5028
HP unknown
You can run 8 high impedance injectors for short periods without a problem. At idle the duty cycle is low enough that they will be ok, and as long as the maximum load is limited in time (eg a drag race) the injector driver will not overheat. But then, if you're using 8 x 1000cc+ injectors, you're not going to maintain full throttle for long periods.
