display randomly maxes out and freezes no live tuning
I have hondata s300 v2 in a 97 civic with a b16 turbo motor. At random times the display will freeze and all diplayed values will go to there and and will sometimes flicker between working and not. This is happening for frequently now. Thanks in advance for your response.
Re: display randomly maxes out and freezes no live tuning
Also says while doing this that the ecu is connected the whole time
Has J12 been cut in the ECU? What spark plugs are you using?
Ngk bkr7e resister type and not sure if it is cut was done by jhpusa in a p28 I got it 2nd hand and was working great when I first installed it
Also at the time its doing it will say its throwing codes but care runs fine and none are in the error code screen when clicked
Check to make sure J12 has been cut. And from Help, About, what version of software are you using?
How do u check that and its the newest one I think 2.4 or 7 somethin like that gotta check again
Look for J12 in the ECU and see if it is cut.
Thank u for your immediate response problem was solved and do to faulty battery ground and also low battery power. Once again greatfull for your help on this matter.
Also j12 wasn't cut cutting that along with bat and I have had no issues since
