Use wideband sensor as a Closed Loop
Posted: Mon Apr 29, 2013 9:48 pm
by Michaelek9
Is there any way to use the LC-1 as a closed loop input?
Re: Use wideband sensor as a Closed Loop
Posted: Tue Apr 30, 2013 8:45 am
No.
Posted: Wed May 01, 2013 10:43 am
by Michaelek9
okay! can i use oem sensor wide band on my PRC ECU? If not.. what type of O2 sensor can you recommend
for close loop input?
Posted: Wed May 01, 2013 10:54 am
The factory wideband will work with the PRC ECU.
Posted: Thu May 02, 2013 4:42 am
by Michaelek9
Can you give me the part number of the OEM Wide band o2 sensor Please!
How many electric wire does it have 4 or 5 ?
Can I use the existing line from the primary narrow band o2 sensor?
Posted: Thu May 02, 2013 9:26 am
What vehcile are you referring to?
Posted: Thu May 02, 2013 1:46 pm
by Michaelek9
Spunkster wrote:What vehcile are you referring to?
K20a from dc5 Jdm with kpro prc ecu swap to ek hatch.
Posted: Thu May 02, 2013 2:08 pm
by Michaelek9
I'm running on the original Primary O2sensor of dc5 engine. I want to remove the LC1 since it is for data logging only.
Is it true that dc5 jdm o2 sensor is a wide band?
How to verify a wideband O2 sensor regardless of wires number?
Posted: Thu May 02, 2013 2:49 pm
Yes it is true. They are all 4 wire sensors. YOu can order this from any Honda/Acura dealer. It is the prmary AF sensor.
