poor man's typr stroker
Posted: Sun Apr 28, 2013 6:23 pm
OK, so kinda new here. this is the mods I have on my current set up
gsr bottom end:
ls crank
eagle ls rods
81.50 pr3 pistons
Race balance on whole rotating assembly
stock 3 layer head gasket
B16a2 head:
blox springs and ti retainers
stock valves, new valve guides
itr Intake
omni 68 mm tb
stock gsr injectors
short ram with blox velocity stack
gsr tranny:
exedy stage 1 clutch
exedy 9.5 lb flywheel
Running hondata s300, looking for a good base map als is it bad to run stock cams on the blox springs and retainers, waiting on getting paid to get some blox type c cams. Thank you.
gsr bottom end:
ls crank
eagle ls rods
81.50 pr3 pistons
B16a2 head:
itr Intake
omni 68 mm tb
stock gsr injectors
gsr tranny:
