need help with this cal asap
Posted: Sun Apr 21, 2013 7:01 pm
by touch
car running lean and when I unplug the laptop the car shut off
Re: need help with this cal asap
Posted: Mon Apr 22, 2013 9:50 am
Check your grounds in the engine bay as it sounds like soemthing is not connected properly and if this continues you will damage the K-Pro and or the ECU.
Posted: Mon Apr 22, 2013 6:38 pm
by touch
my ground its ok. when I run a stock base map car run fine but when I run that map it act up running lean and shut off not sure if its the map or not
Posted: Tue Apr 23, 2013 9:29 am
IF another calibrations works and that one does not, stop using it and use the calibraiton that does work.
