Ngk wideband wiring
way2fastfou88
Ngk wideband wiring
I have this computer http://www.kstuned.com/products/the-black-ecu its a jdm computer.Im trying to connect the ngk wideband up ive read the plx wideband setup on hondata website but it says white and grey wires but the ngk comes with a yellow and brown. What does the yellow wire need to be connected to and where does the brown wire go to. Any help would be appreciated.
Re: Ngk wideband wiring
YOu will need to look at the instrctions that came with your wideband to determine what those wires are.
http://www.ngksparkplugs.com/pdf/AFX_Tu ... REV_06.pdf
I just wired mine up, used the ELD input and disabled the ELD error in the settings. use the same ground for the analog output as you do the wideband itself. If you use the ELD make sure you clip the two resistors that Hondata suggests. brown is ground, yellow is input. make sure you set the lambda conversion and other closed loop settings.
hope this helps
hope this helps
