Base calibartions for stock D16Z6 turbo?
Posted: Tue Apr 16, 2013 9:10 pm
by szula
Hi, how are you guys? I'm looking for base calibrations for a stock D16Z6 turbo build, this are the details:
- Stock internals
- Stock compression
- RC Fuel Injectors 440cc (high impedance)
- 255 lph walbro fuel pump
- 3 bar map sensor
- 7-8 psi on the turbo (it will depend on the base calibrations that I get here)
Someone have a file to download??
If you could help me I would be grateful, thanks!!
Re: Base calibartions for stock D16Z6 turbo?
Posted: Thu Apr 25, 2013 4:42 pm
by alston3ptswish
I just got my d16z6 dyno tuned. stock internals, RC 440's. What turbo are you using. I'm using a dsm 2nd gen t25. I can share my tune with you if you'd like since there's a lack of d16 turbo tunes on this forum
Posted: Fri Apr 26, 2013 5:15 am
by szula
Hi, thank you for your answer! I'm thinking of using a t3/t4 turbo because it comes with the turbo kit. The specs are this:
Compressor Specs :
3" Compressor Inlet
3.000" or 76.20mm Major
1.988" or 50.50mm Minor
Compressor .50 A.R.
Compressor 57 Trim
M24 / T4 Compressor Housing
Turbine Specs :
T3 Type Turbine
11 Blade Type
2.25" Exducer
Turbine .64 A.R.
Turbine 76 Trim
2.560 " or 65.04mm Major
2.204 " or 56.00mm Minor
Exhaust Outlet Flange with 5 bolt design
How many psi do you have on your turbo?
Thank you so much again for taking the time to answer me!
Posted: Fri Apr 26, 2013 6:27 pm
by alston3ptswish
Tune is 8-12 psi. It should work fairly well with that turbo. But please have a wideband hooked up to know what AFR your getting. I used 2-3 d16 calibrations before i went to the dyno and the last calibration i thought was on point bu the tuner said I was detonating a little bit with that tune. If i get some time tomorrow I'll post it up for you
Posted: Sun May 05, 2013 5:14 pm
by alston3ptswish
I didnt forget about you bud. I tried pulling the tune from the ECU but apparently you can corrupt the calibration doing this. I'm gonna have to email my tuner and see if he kept my tune on file and if he can email it to me.
Posted: Sun May 05, 2013 6:21 pm
by szula
alston3ptswish wrote:I didnt forget about you bud. I tried pulling the tune from the ECU but apparently you can corrupt the calibration doing this. I'm gonna have to email my tuner and see if he kept my tune on file and if he can email it to me.
Great!! I will wait for you, thank you so much!!!
Posted: Thu Jun 13, 2013 1:02 pm
by zombie247
where is the calibration? bump
Posted: Wed Jul 17, 2013 5:13 pm
by szula
zombie247 wrote:where is the calibration? bump
Still no news. I'll let you know if he contact me by pm!
