Injection times
Posted: Tue Apr 09, 2013 4:25 am
by angelf1974
Why are fluctuations in the injection times? Is this normal?
Re: Injection times
Posted: Tue Apr 09, 2013 7:56 am
Not normal. Seems to start at VTEC switch. We'll try the calibration in our car.
Re: Injection times
Posted: Tue Apr 09, 2013 9:45 am
by angelf1974
Hondata wrote:Not normal. Seems to start at VTEC switch. We'll try the calibration in our car.
Thank you. I will wait for your answer. I discovered it in the last datalogs, some time ago there are not this fluctuations.
Re: Injection times
Posted: Wed Apr 10, 2013 12:20 pm
by angelf1974
Please, one more thing. Is it safe to use the car in these conditions?
Re: Injection times
Posted: Wed Apr 10, 2013 3:27 pm
Seems ok here (we can't test the exact calibration because we do not have an automatic). I would try FlashProManager version 1.5.0 and also check & clean your engine grounds, as some of the engine sensors are changing value at VTEC, which coincides with the odd behaviour.
Re: Injection times
Posted: Thu Apr 11, 2013 4:44 am
by angelf1974
Hondata wrote:Seems ok here (we can't test the exact calibration because we do not have an automatic). I would try FlashProManager version 1.5.0 and also check & clean your engine grounds, as some of the engine sensors are changing value at VTEC, which coincides with the odd behaviour.
My car is manual.
I will try the new version and check grounds, thank you.
Re: Injection times
Posted: Thu Apr 11, 2013 7:38 am
angelf1974 wrote:My car is manual.
Sorry, it is indeed a manual calibration.
Re: Injection times
Posted: Sat Apr 13, 2013 4:04 am
by angelf1974
Well, I tried the same calibration but with FalshPro Manager 1.5.1 and everything remains as before.
The engine grounds seems to be ok.
Then I tried the base map calibration and works fine, no fluctuations. I think there is a problem with my calibration but I can“t discover it. It is always at WOT (in closed loop it is ok), and always in high cams.
Re: Injection times
Posted: Sun Apr 14, 2013 8:15 am
Have you tried starting with a new calibration and importing the fuel and ignition tables from your current calibration?
Re: Injection times
Posted: Mon Apr 15, 2013 12:31 pm
by angelf1974
Base map.
Base map + fuel tables
Re: Injection times
Posted: Mon Apr 15, 2013 1:50 pm
Can you import the fuel tables one by one to narrow down which is causing the problem?
Re: Injection times
Posted: Tue Apr 16, 2013 4:10 am
by angelf1974
Hondata wrote:Can you import the fuel tables one by one to narrow down which is causing the problem?
I have tried it, the fluctuations appears when I import the 25 degrees fuel table (high cam)
Another test, I have a old calibration and its datalog, it was ok but, if I load this calibration now then appears this fluctuations.
Could it be due to low quality fuel?
