Computer blue screens when hondata USB connected..
Posted: Sun Apr 07, 2013 9:14 pm
by b20luda
Im using a new Dell computer with Windows 7, when connecting to Hondata the computer will sometimes blue screen and force a restart.. I have tried another computer also using windows 7, and it does the same thing.
It seems to happen most when starting the car.. but it has happened at other random times as well..
My old laptop with XP seems to work fine, is there something i can do or change to help this, i've tryed running in compatibility mode and it still does it.
Anyone else having issues?... This computer is only a couple months old, and the other i used is about a year old.. both work fine otherwise.
Re: Computer blue screens when hondata USB connected..
Posted: Mon Apr 08, 2013 7:00 am
With the S300 connected, open the control manager and uninstall the USB drivers. Make sure to check 'remove driver files' too. Then unplug, replug and manually install the drivers from the SManager directory.
Posted: Tue Apr 09, 2013 7:44 pm
by b20luda
Hondata wrote:With the S300 connected, open the control manager and uninstall the USB drivers. Make sure to check 'remove driver files' too. Then unplug, replug and manually install the drivers from the SManager directory.
Is there another way to do this without the S300 connected? It blue screens before i can do all this..
Posted: Wed Apr 10, 2013 8:09 am
With the s300 disconnected:
1. Download the FTDI uninstaller from here
2. Open the downloaded zip file and run 'CDMuninstallerGUI'
3. It should ask you for administrator access.
4. Change the product ID to F5FA and click 'Add'
5. Click 'Remove Devices' It should say something about removing drivers.
6. Click 'Close'. It may say something about not installing correctly, but tell it that it worked.
If you then plug in the s300, when it asks for drivers direct it to the SManager directory. Windows 7 often does not even ask you for drivers, so you have to follow the manual driver installation process. See the help file
Posted: Wed Apr 10, 2013 7:18 pm
by b20luda
Thanks Hondata, it seems to be working now. Do all Windows 7 users have to do this?
Posted: Thu Apr 11, 2013 7:28 am
No, it was because the USB drivers are fairly common and shared between different devices. If one other device installs a later version of the drivers then it causes problems. Also I've noticed on Windows 7 if you boot the laptop with the s300 (or KPro) connected it will sometimes blue screen - this is a bug with the USB drivers (which we do not make and therefore can't fix).
Yesterday we just finished the Windows hardware signing hoop jumping process and will supply a newer version of USB drivers for the next release, which should help things for Windows 7 & 8.
Posted: Fri May 03, 2013 7:48 pm
by b20luda
i downloaded this new version, it started blue screening again.. any ideas or suggestions
Posted: Sun May 05, 2013 1:20 pm
What version?
Posted: Sun May 05, 2013 2:20 pm
by b20luda
2.2.6
Posted: Wed May 15, 2013 5:39 pm
by b20luda
any ideas guys?
Posted: Thu May 16, 2013 7:48 am
Run the instructions to uninstall the drivers and re-install from the SManager directory.
