VSA/traction probleme when tuning?
Posted: Fri Apr 05, 2013 9:41 am
by Garrett_si
Does someone notice power reduction on dyno sometimes?
I tune 2 civic Si 2012 last week, and sometimes the power in the powerband drop
I attach the dyno sheet, and the datalog files
Ignition, throttle, cam don't change at all during the run.
both cars do it.
Re: VSA/traction probleme when tuning?
Posted: Fri Apr 05, 2013 10:07 am
You need to post the calibration that was used when the datalog was made.
Posted: Tue Apr 16, 2013 10:17 am
by Garrett_si
here is the cal file used
I did 3 dynoruns with this calibration.
2 were fine, one has the dip
Posted: Tue Apr 16, 2013 12:59 pm
The only thing I can see is that it gets a little leaner in the 6000-7000 rpm range on the datalog, but I do not see anything else in either the datalog or the calibration.
Posted: Wed May 01, 2013 7:08 pm
by Garrett_si
I see the same thing, and I don't understand why the car do that, this happens a couple of time the same day on 2 differents civic Si 2012
Posted: Thu May 02, 2013 10:22 am
The only other thing that I can see that could be effecting this is the knock ignition limit tables where there are negative values. Read more about this at http://www.hondata.com/help/flashpro/kn ... tsub=knock
