VSA/traction probleme when tuning?
Garrett_si
Post by Garrett_si »
Does someone notice power reduction on dyno sometimes?
I tune 2 civic Si 2012 last week, and sometimes the power in the powerband drop
I attach the dyno sheet, and the datalog files
Ignition, throttle, cam don't change at all during the run.
both cars do it.
Re: VSA/traction probleme when tuning?
You need to post the calibration that was used when the datalog was made.
Garrett_si
here is the cal file used
I did 3 dynoruns with this calibration.
2 were fine, one has the dip
The only thing I can see is that it gets a little leaner in the 6000-7000 rpm range on the datalog, but I do not see anything else in either the datalog or the calibration.
Garrett_si
I see the same thing, and I don't understand why the car do that, this happens a couple of time the same day on 2 differents civic Si 2012
The only other thing that I can see that could be effecting this is the knock ignition limit tables where there are negative values. Read more about this at http://www.hondata.com/help/flashpro/kn ... tsub=knock
