analog datalogging saved?
aceman187443
Post by aceman187443 »
Where are the analog inputs recorded to? I do not see them show up on the graph. All I see during playback in graph is : rpm,vss,tps,map and inj,ign,duty. Are the recorded and saved somewhere else? Thank you.
Re: analog datalogging saved?
You must set up your graphing templates for the sensors you want it to display. Right click on the graph and select define templates.
