MAP sensor protection
Posted: Wed Apr 03, 2013 6:23 pm
by 9queSt
is there any ideas to protect against a map sensor failure. i.e. if im in the middle of a drag race @ 7000rpm and 25psi. the map sensor fails (vacuum line or wire failure). Smanager now drastically decreases fuel and increases timing.
How can I protect against this?
Re: MAP sensor protection
Posted: Thu Apr 04, 2013 9:37 am
There is no way to protect against this. The map sensor is required for the engine to run correctly. You can use a wideband and use lean protection, but it cannot prevent a map sensor failure.
Posted: Thu Apr 04, 2013 10:21 am
A MAP sensor failure ill give a 3000 rpm limit
Posted: Thu Apr 04, 2013 7:30 pm
by Jan Niemi
Hondata wrote:A MAP sensor failure ill give a 3000 rpm limit
that would constitute no signal to the ECU. If a vacuum line comes off, then the signal is still there, so it won't go to 3000 rpm
