Does anyone have a map fo K20A2 please? RBC, 3" Exhaust?
Posted: Tue Apr 02, 2013 9:35 am
by Dan Page
Hiya
Does anyone have a basemap I can download please?
I'm going to get it mapped properly next month but with buying the K Pro this month funds are a little tight.
K20A2 UK Engine
PRA UK ECU
RBC Inlet Manifold
Hybrid Racing Exhaust Manifold
3" full exhaust with no cat
K Tuned K swap Induction Kit with Velocity STack filter
Fuel pressure set to 50 psi
Walbro 255lph pump
I've loaded the tuned european map and it seems to rev limit at 4000 rpm but before hand on stock ecu it was running fine other than ELD and secondary o2 error.
Thank you and your help will be very much appreciated.
Dan
Re: Does anyone have a map fo K20A2 please? RBC, 3" Exhaust?
Posted: Tue Apr 02, 2013 10:21 am
by Dan Page
**Update**
I've just loaded the "stock K20A2 map" from kmanager software and it now seems to run better and pretty much as it used too.
I've disabled secondary o2 (as I only have primary wired up) and disabled ELD and multiplexer. I thought my CEL would have gone out but it's still on though?
Obviously with this map I'm not seeing any benefits over stock ecu though right?
Posted: Tue Apr 02, 2013 10:47 am
by Nazul
U have to wire up the second one as well, even if u dont use it. Otherwise it will give u a cell.
Posted: Tue Apr 02, 2013 12:20 pm
by Dan Page
Can you not wire a resister or something just to fool it? Sorry if that was a really dumb question. Lol.
Posted: Tue Apr 02, 2013 12:31 pm
by Nazul
Yes a lamda fooler its called.
Posted: Tue Apr 02, 2013 9:46 pm
by keto06
use the map I posted in the other thread and post a log.
Posted: Thu Apr 04, 2013 2:32 pm
by Dan Page
http://www.filedropper.com/normaldrivingdanpage
http://www.filedropper.com/3rdgearpullsdanpage
Here's a couple of data logs. First one I went for a normal drive stop start traffic kind of thing from stone cold and the second one is five 3rd gear pulls from 1500 rpm to the limiter.
Thank you
Dan
