Wideband Closed-Loop rpm limit
Touge Master
Post by Touge Master »
Hi there,
I'm trying to configure the smanager for WOT closed-loop based on wideband signal.
Everything seems ok until car hits 5.000 rpm and ECU change to open-loop.
I've seen that in the Closed Loop advance tab, when i change the rpm limit, the program don't let me set numbers above 8.000 rpm and even if a set to 8.000 rpm when i save the file this value is reset to 5.000 rpm. There is no way of make it bigger.
Is the WOT wideband closed-loop internaly limited to 5.000 rpm? Is a program bug? I'm missing something?
Thanks in advance.
Best regards.
Kouzan Racing Engineering
Re: Wideband Closed-Loop rpm limit
This appears to be a software bug. We will look into it.
The maximum rpm value that the ECU can use is 8000 rpm.
Not saving/reloading is a big, which has been fixed.
We plan to make a beta release this week.
