s300 wire unplugged, cause engine flood?
CKnight90
Post by CKnight90 »
I had injectors serviced.
Checked for grounded wire.
Put serviced injectors in today..
Engine still flood.
Found out 1 wire on my ecu is unplugged. From the ecu to the plastic connector.
Re: s300 wire unplugged, cause engine flood?
This is too vague. What wire? What pin? What connector?
Have you tried the ECU on a known working vehicle?
CKnight90
Post by CKnight90 »
http://www.youtube.com/watch?v=XakliR8B ... e=youtu.be
No one else has the setup like I do around here or I would try it another vehicle.
95 Acura Integra GSR - B16a - 8psi - E85 -1000cc Injectors - Hondata S300
