Also I take it I would require bigger injectors, if so how big?
Is there anything else I would require?
Thanks.
Yes you need a hondata supported OBD1 ECU..yes there is a conversion harness (or you can get a P28 with OBD2 connector)..ek9_civic wrote:Hi guys, I am looking to get a Hondata ECU on my EK9 Civic. The thing is my car isn't listed as its OBD2, therefore I take it I must get an OBD1 ECU, a Hondata Kit for this and then a conversion wires to change OBD2 to OBD1. Is this correct?
Thanks.
