d16y8 stock
Posted: Mon Mar 18, 2013 7:26 am
by i-VTEC
Hello i need a s300 d16y8 basemap does anyone can help me please? it´s an european civic.
thanks
Re: d16y8 stock
Posted: Tue Mar 19, 2013 3:40 pm
by i-VTEC
can anibody help me? i realy need a basemap can i use a d16z6?
Re: d16y8 stock
Posted: Thu Mar 21, 2013 7:21 am
by i-VTEC
no one?
Re: d16y8 stock
Posted: Wed Mar 27, 2013 8:21 pm
by keto06
why put s300 on a stock y8?
Re: d16y8 stock
Posted: Thu Mar 28, 2013 3:06 am
by i-VTEC
keto06 wrote:why put s300 on a stock y8?
hello
because it´s intalled in a civic eg4 obd1 can i put the original ecu on it?
Re: d16y8 stock
Posted: Thu Mar 28, 2013 9:34 am
by keto06
Re: d16y8 stock
Posted: Thu Mar 28, 2013 5:20 pm
by i-VTEC
I Can put a p2p with a Wiring conversion in europe the d16y8 dont have the second o2 sensor my problem is the knock sensor i think
Re: d16y8 stock
Posted: Fri Mar 29, 2013 12:24 am
by khmoe
The Hondata thred is mine :(
Do not change mecanical timming.
I had to widen the holes in the dizzy so i could clock it more towards the firewall. Then you manage to time it to 12' degree.
Use the d16z6 base map and you are ok.
The y8 head likes a few degree less timing so you could altert the map slightly.
Have'nt had my car on the dyno yet :(
Going to do it within the nex couple of months, but now the motor is fully built :( so no valid data for a stock y8.
Re: d16y8 stock
Posted: Fri Mar 29, 2013 4:50 am
by i-VTEC
Ok so you put the d16z6 map and set the timing on the map to 12? is that it and then you tune from there? i´m confused because i think the european cars are slight diferent than the american cars.
thanks
Re: d16y8 stock
Posted: Fri Mar 29, 2013 5:32 am
by khmoe
Use the z6 map.
Set timming in hondata to 12
And turn dizzy until it lines up with the middel line on the crank when useing a timminglight.
My car is from germany, but every y8 is made in the USA.
Btw i'm from norway
Re: d16y8 stock
Posted: Fri Mar 29, 2013 6:23 am
by i-VTEC
Thanks You are helping me a lot Can You show me a Photo in what line should it be line up?
Re: d16y8 stock
Posted: Fri Mar 29, 2013 6:56 am
by khmoe
Middel line of the 3 on the crank gear.
Look in any car manual to see it :)
Re: d16y8 stock
Posted: Sun Mar 31, 2013 3:50 am
by i-VTEC
Ok Thanks :-) im gonna make the swapp now :-)
