My Driving Template
Posted: Sat Mar 16, 2013 9:21 am
Here is my display that I made for quick and easy info. I use it for driving and while reviewing datalogs. I spent a good amount of time tweaking the Air/Fuel bar at the bottom so that it will show Red for Over Rich and Over Lean, Yellow for Ideal LOAD richness and cautionairy lean, and Green for cruising lambda levels. Also the bar will go dark green when no fuel is added and you go full lean such as when you go off throttle during decelleration. The RPM, Air/Fuel, Ignition degrees, Coolant temp, and Intake temp are all visible with the tables over the rest of the gauges. As well as the Air/Fuel bar. All will also change red at propper levels for warning you. (such as if your over rich during a pull, pass redline, overheat, ect.) As just a added benifate of it peeking out under the tables is when you click datalog to start recording, the rest of the display shows over it. (not my doing but find it convenient) Also see how i have my datalog graphs overlay the other half of my screen so i can see everything more clearly as i scroll through them. Here are several examples of each instance to show the Air/Fuel bar functionality. Hope you guys enjoy.
NOTE: was made for b16 with a stock redline of 8200
Cruising
During Pull
Closed Throttle
Over Rich
Slightly Lean
Over Lean
With the tables overlaping the rest of the gauges
Also note that above layout is on a 17" laptop screen, you may need to mess with your window sizes to get it to look the same.
Feel free to leave me feedback on how you like or hate it lol. I think it has high functionality for minimal space personally.
Cruising
During Pull
Closed Throttle
Over Rich
Slightly Lean
Over Lean
