Under the settings, sensor overlay tab i selected digital 0. This is what my wideband is connected to.
The analog portion of my wideband is connected to b6 (analog 2). R2 &R3 cut. Does autotune use digital 0 or analog 2?
digital/ analog wodeband input
Re: digital/ analog wodeband input
You cannot use autotune with the inputs on the s300 board. They are for datalogging only. For autotune to work you must input the wideband signal into one of hte ECU inputs listed in the software.
the wideband analog signal is inputted to b6 with r2 and r3 cut. I selected b6 to run closed loop. Is that what auto tune uses?Spunkster wrote:You cannot use autotune with the inputs on the s300 board. They are for datalogging only. For autotune to work you must input the wideband signal into one of hte ECU inputs listed in the software.
Yes, that is what it must use.
