Barometric correction
Posted: Fri Mar 15, 2013 4:34 am
by Touge Master
Hi there,
This might be a silly question but i couldn't find the answer searching around.
Is there any sort of barometric correction for MAP or AFM/MAP hybrid calibrations?
Thanks in advance.
Best regards.
Re: Barometric correction
Posted: Fri Mar 15, 2013 11:54 am
By nature a speed density system automatically compensates for barometric pressure.
Posted: Fri Mar 15, 2013 2:44 pm
by Touge Master
Hondata wrote:By nature a speed density system automatically compensates for barometric pressure.
Sorry but i can't agree 100% with that. AFM based systems can compensate altitude but MAP based fuelling systems needs correction because of the back pressure influence on volumetric efficiency.
I've worked with other systems that uses 4D fuel tables or other baro correction method.
So. Flashpro ready Honda ECUs have baro sensor or uses WOT (100% TPS) MAP reading to figure out barometric pressure?
I don't want to arge with you just trying to figure out how to solve some fuelling issues i've found with big altitud changes.
Thanks in advance.
