Tuning ITB without MAP sensor. Help!
How would you tune a b16a with ITBs without a MAP sensor? Is it possible to use the MAP with ITBs?
Re: Tuning ITB without MAP sensor. Help!
yes, it is possible to use a MAP with ITB's. I have tuned a car with it. You need a good vacuum box to make the setup work properly.CivicVTi wrote:How would you tune a b16a with ITBs without a MAP sensor? Is it possible to use the MAP with ITBs?
