need calibration for a high compression h23 vtec
mikey76133
Post by mikey76133 »
i have a h23 vtec with 880cc injector, 240 compression need base map thx
hpmx18
Re: need calibration for a high compression h23 vtec
Post by hpmx18 »
mikey76133 wrote:i have a h23 vtec with 880cc injector, 240 compression need base map thx
start with h22map and add about 25% fuel and get car to idle about 1000-1300 depending on your compression if you have a wideband it'll be much easier
LGMotoring
IG:Lgmotoring_official
Lgmotoring.com
mikey76133
having problem setting up in injector, i have 880cc injector but i put 550cc and everything running rich like crazy can u check out my map thx.
hpmx18
Post by hpmx18 »
if you have 880 you need to put 880 not 550
LGMotoring
Lgmotoring.com
mikey76133
I put it on 880 but the engine keeps on stalling out.
mikey76133
ok i look at my injectors 3 of them are precision 6280 injectors and one says precision 6290 injectors. anybody knows what kind of injectors are these, and the seller i got them from said these were 880cc.
mikey76133
ok, just got it dyno jet tune h23 vtec making 200 hp with 160tq. anybody can look at the map and give me anything i should change thx.
