Base calibrations for d16z6 turbo ???
Posted: Tue Feb 26, 2013 5:21 pm
by streetcopa09
Base calibrations for d16z6 turbo at 7 psi stock injectors stock internal ???you have a file to download??
if you could help me I would be grateful thanks
Re: Base calibrations for d16z6 turbo ???
Posted: Tue Feb 26, 2013 5:35 pm
You cannot run boost on stock injectors, you will run out of duty cycle.
Posted: Wed Feb 27, 2013 5:05 am
by streetcopa09
What size of injectors do you recommend? I do not want to get too much power 300hp max, could you help me later for the calibration of my car? in Switzerland are not able;) thanks sorry for the English
Posted: Wed Feb 27, 2013 10:51 am
You will need a minimum of 550cc to 650cc injectors for that power level.
Posted: Wed Feb 27, 2013 12:11 pm
by streetcopa09
thanks'll let you know as soon as I more ... but after you in that case you would have to give me the data for ECU calibration?? thanks
Posted: Wed Feb 27, 2013 12:29 pm
Talk to the dealer you purchased the s300 from and they should be able to help you with a base calibration.
Posted: Wed Feb 27, 2013 12:32 pm
by streetcopa09
how many hp with 450cc injector ??
Posted: Wed Feb 27, 2013 4:05 pm
by streetcopa09
but as you said here in my part are not able, just now I will come s300'll see what to do (shipped from USA) but I read your post you think I could start putting a supercharger for calibration and work on it or is it too different? ? admitting to change injectors and fuel pump
The machine will now go with stock ECU, stock injectors, stock fuel pump but does not do much ... you start to feel the pressure at the end of 2 top 3 .... I'm doing a experiment;)
thanks after not bother you any more;)
