jdm ep3 type r kpro issues
Dean s
Post by Dean s »
Fitted my kpro the other day its running the correct basemap but the car keeps trowing up the CEL checked the codes and it was given me p0134 no activity in oxygen sensor bank one anyone have any ideas why tis is happening car is also drinking petrol aswel because of it im only new to this so dont now much about the hondatas
Nazul
Re: jdm ep3 type r kpro issues
Post by Nazul »
Replace the oxygen sensor with a new OEM one.
Dean s
Post by Dean s »
Thing is i put the stock ecu back in and the CEL doesn come on and the.car runs perfect so dont tink its the oxygen sensor
What was the stock part number on ECU that was originally in the car?
Dean s
Post by Dean s »
I duno its back in the car now il check in the morning all i now is that its a prd ecu ive got the kpro tere i can give u the number off that if it helps
Nazul
Post by Nazul »
Spunkster are u saying this is a software problem of hondata?
So i replaced mine for nothing then? It gave the error right after fitting the hondata, mine is a EU EP3
I do not have enough information to even know what he has yet.
Dean s
Post by Dean s »
stock part number is 37820-prd-013
Are you uploading a PRA or PRB based calibration (from Notes tab of calibration window)?
Dean s
Post by Dean s »
Im pretty sure its prb i didnt upload it the company i bought the ecu off did i have not got kmanage so cant check it
This is important and you need to find out or youcould be on a wild goose chase.
Dean s
Post by Dean s »
il find out tomoro could it be possible that the pra calibration was uploaded and its causing the code to come up since the uk ep3 type r use a narrow band oxygen sensor and the jdm ep3 type r use a wide band oxygen sensor?
That is a very real possibility
Dean s
Post by Dean s »
will find out tomoro and let you know how i get on
Dean s
Post by Dean s »
rite i found out what calibration was put on my kpro it was for a pra ecu.Could anyone tell me what calibration i should put on my kpro tere is alot of them to download off kmanager iv a few mods done decat, manifold, itg maxogen, and rbc intake manifold thanks
