K20A2 KAL help
ohsnapzitzmeng
K20A2 KAL help
Post by ohsnapzitzmeng »
hello i just got my kpro back today and i know alot of you may hate me but yes im a noob...
i have a 2002 rsx-s living in WI and was hoping you could help me out with a map...
performance mod list:
invidia q300 catback
HPS intake
Hondata IMG
str-up race headers
thanks in advance
ohsnapzitzmeng
Re: K20A2 KAL help
heres what i have so far, edits would be nice thanks
ohsnapzitzmeng
Re: K20A2 KAL help
bump help needed thanks
Nazul
Re: K20A2 KAL help
Post by Nazul »
I'll have a look when i have the time.
In the meantime, where do u live, do u have a wideband or narrowband?
And its impossible to tune the hondata perfectly without air fuel measurement.
Even if u adapt the kal, then the cam angles are not optimal either.
The car will run, but too lean or rich, and you wont have max hp.
Nazul
Re: K20A2 KAL help
Post by Nazul »
tune looks pretty good for ihe setup
ohsnapzitzmeng
Re: K20A2 KAL help
Nazul wrote:I'll have a look when i have the time.
i live in mid-west area, but i only drive anything but winter seasons. im just using my stock 02 sensors (secondary is hooked to a 02 non-fouler bong) as of now. what are the benefits of a wideband?
Nazul
Re: K20A2 KAL help
Post by Nazul »
U can measure your airfuel at all time, if you put a meter to it, u can even see it in your car.
By this you can tune your map yourself and see if the airfuel is getting better.
Or u can use your datalogs then and check the values in hondata that it measures.
With a narrowband you cannot see the values.
But i believe the RSX has a wideband standard.
ohsnapzitzmeng
Re: K20A2 KAL help
Nazul wrote:U can measure your airfuel at all time, if you put a meter to it, u can even see it in your car.
yes, i believe the 05-06 are the ones who have to worry about the wideband
ohsnapzitzmeng
Re: K20A2 KAL help
adjusting my vtec, would i have to also adjust my a/f ratios too?
Nazul
Re: K20A2 KAL help
Post by Nazul »
Yes ofcourse, the intake valves remain open longer which result in more oxygen, so you have to compensate with more fuel.
ohsnapzitzmeng
Re: K20A2 KAL help
Nazul wrote:Yes ofcourse, the intake valves remain open longer which result in more oxygen, so you have to compensate with more fuel.
could you help me out in adjusting the a/f ratio my tables?
Nazul
Re: K20A2 KAL help
Post by Nazul »
This is impossible to predict how to compensate unless you log with the wideband or go to a tuner.
Can you make a log driving around in vtec then i can check it, but im not a pro in that.
Perhaps its better u ask someone who does etuning here.
ohsnapzitzmeng
Re: K20A2 KAL help
Nazul wrote:This is impossible to predict how to compensate unless you log with the wideband or go to a tuner.
thanks for your advice, i will be able to DL a log in vtec in spring, would you have any recconmended etuners?
mdelrio1991
Re: K20A2 KAL help
Post by mdelrio1991 »
load a 3rd gear datalog
ohsnapzitzmeng
Re: K20A2 KAL help
