test outputs
Posted: Tue Jan 08, 2013 6:51 pm
by sicones
I cannot get the test outputs function to work, am I missing something here or is it broken? I'm using v2.2.3.
Re: test outputs
Posted: Wed Jan 09, 2013 2:33 pm
What do you mean exactly when you say it does not work? Do you have your calibration loaded?
Re: test outputs
Posted: Thu Jan 10, 2013 3:42 pm
by sicones
Of course, just uploaded the new calibration after the update. Cycled the key to clear the CEL that usually happens after an update. I tried it with datalogging on and datalogging off. It doesn't work.
Re: test outputs
Posted: Thu Jan 10, 2013 4:30 pm
What function are you trying to test?
Re: test outputs
Posted: Thu Jan 10, 2013 5:02 pm
by sicones
I tried all of them, but I really want to test A10 for my nitrous solenoid.
Re: test outputs
Posted: Thu Jan 10, 2013 6:06 pm
Download the newest Beta version which was just uploaded. I have tested this and it is working. VTEC output can only be checked while the engine is running as you need a certain RPM for it to activate.
Re: test outputs
Posted: Thu Jan 10, 2013 7:46 pm
by sicones
I just tried it with v2.2.4, still doesn't work. I also did an Erase ECU command and re-uploaded, didn't help. I'm not to concerned with this feature but it would be nice, ecm link has had this for a while.
Re: test outputs
Posted: Fri Jan 11, 2013 9:08 am
It does work when we test it here. What output are you trying to test, exactly how are you testing it, and how have you determined that it does not work?
Re: test outputs
Posted: Fri Jan 11, 2013 6:36 pm
by sicones
I plug in the laptop, put key in II, upload calibration, start datalogging, when I go to the test outputs window checking any of the boxes does nothing.
Re: test outputs
Posted: Fri Jan 11, 2013 6:44 pm
by sicones
How do I know it doesn't work? Cooling fan doesn't come, fuel pump doesn't run (walbro is loud as hell), nitrous solenoid and relay no clicky, no click from AC clutch.
Re: test outputs
Posted: Sat Jan 12, 2013 9:14 am
Try it without datalogging.
Re: test outputs
Posted: Sat Jan 12, 2013 11:38 am
by sicones
Still doesn't work, I've tried every possible scenario except another laptop which should not matter. Even XP mode on my Win7 computer. Opened a brand new calibration and uploaded didn't work either. Also, that bug is still there under secondary tables parameter, the Nitrous Active check boxes don't stay checked after a save and reload.
Re: test outputs
Posted: Sun Jan 13, 2013 9:38 am
Is 'Realtime Update' set on?
Re: test outputs
Posted: Wed Jan 16, 2013 3:41 pm
by sicones
That was it, thanks.
