full throttle shift help!!!!
vteckiller
Post by vteckiller »
hello
I would like to connect my switch but I have a problem ..
Connector I have the E22 ecu ok
but I'm going to switch the +12 V or ground???? thank you
my car civic type r ep3 europeenne
hondata kpro
Re: full throttle shift help!!!!
Brake switch input should be powered, but check with a multimeter to be sure before connecting it to the ECU.
vteckiller
thank you
+12 V switch on and switch to the ecu E22
sorry
why I measured with a multimeter??
To make sure you are not giving power to a ground input or ground to a powered input. This will help you prevent damaging the ECU or blowing fuses.
vteckiller
oki
thank you
vteckiller
hello if I use my E16 ecu pin.
switch must be connected to ground???
thank you
vteckiller
what is the best solution E16 or E22???
05typeR
Post by 05typeR »
E29 seems to be the simplest in my opinion and the connection is right by the driver's clutch pedal, kinda.
Just needs a ground.
vteckiller
thank you to you for your help..
my car is european driver is left.
205 connector is on the left of the clutch pedal??
thank you
05typeR
Post by 05typeR »
My car is also a EDM but it's right hand drive, LHD is similar with same connections, it will be by the driver's accel pedal.
vteckiller
thank you for your tips
