Page 1 of 2
S300 problems
Posted: Fri Dec 14, 2012 1:27 am
by Monnoracing
I dont have the numbers for you at the moment. Ecu has been working for the last 2 years, then tonight it decides to almost act like certain files are corrupt and immediately triggers a CEL. My thought is the new security feature having something to do with it.
Re: S300 problems
Posted: Fri Dec 14, 2012 1:42 am
by Monnoracing
yep it just picks and chooses when it wants to shut down
Re: S300 problems
Posted: Fri Dec 14, 2012 8:28 am
Switch off the ignition, shut down SManager, restart SManager and then re-upload the calibration.
Re: S300 problems
Posted: Fri Dec 14, 2012 9:36 am
by Monnoracing
That allowed me to load the tunes that were not. Why all of a sudden would it start doing this? I have jumped from file to file while the car has been running before and no problems.
Re: S300 problems
Posted: Fri Dec 14, 2012 10:29 am
Any time you completely change a calibratio you should close and reopen the software or you will end up with a corrupted calibration. IT has always been this way.
Re: S300 problems
Posted: Fri Dec 14, 2012 12:35 pm
by Monnoracing
It may have always been this way but something has happened since last update. I have had the car die when changing from file to file but that has been 2 times ever.
Re: S300 problems
Posted: Fri Dec 14, 2012 12:50 pm
by Monnoracing
And when that happened I just had to restart the car not close down everything and I had no CEL with no code.
Re: S300 problems
Posted: Fri Dec 14, 2012 11:15 pm
by Monnoracing
- s300-0886
- 90 civic si
- 37820-p28-a52
- wideband input and nitrous 1 output to relay
- Unable to upload files now or atleast no longer shows a progress bar. When it will start runs rich and main sign of a problem when the s300 is plugged up the main relay clicks its 2 times but very fast. With my other ecu it clicks 2 times with a pause between like normal. Any ideas? Also on my way home just upped and started running rich and had to be towed home.
Re: S300 problems
Posted: Mon Dec 17, 2012 10:26 am
Go to Online, and click Erase ECU. THen that finishes, close the program and reopen it m then upload a fresh calibration from File new. Does that work?
Re: S300 problems
Posted: Mon Dec 17, 2012 1:03 pm
by Monnoracing
I tried that Spunkster with no luck. The red led inside is on solid and the green blinks every 10 sec. I am using a friends ecu right now with no problems. I was going to install my s300 chip in his ecu and see if its my ecu. If its the s300 chip what actions do I need to take to get this fixed?
Re: S300 problems
Posted: Tue Dec 18, 2012 1:52 pm
by Monnoracing
Here is a screen shot of the failed notice when I am trying to setup the newest beta version or any of the versions now. Even after this failure happens s manager opens and I can work the other computer. I was able to download the file that was currently on the chip and it was not my file. I am going to use a different laptop tonight and see what happens,
Re: S300 problems
Posted: Tue Dec 18, 2012 4:23 pm
If that does not work, let us know here and then send an email to support <at> hondata.com with the following and I will issue an RMA and give you further
instructions (include a link to this thread):
Name:
Address:
Phone:
Email:
Serial#:
Brief Description of Problem:
Re: S300 problems
Posted: Tue Dec 18, 2012 7:32 pm
by Monnoracing
Will do. Thanks
Re: S300 problems
Posted: Sun Dec 23, 2012 5:37 pm
by Monnoracing
No luck with dl the latest version and erasing the ecu. I am still getting a upload error and a solid red led on.
Re: S300 problems
Posted: Wed Jan 02, 2013 11:31 am
Have you sent this in yet?
