FlashPro Manager 1370 crash
alollini
Post by alollini »
- serial number of your FlashPro : FP-CRZ-INT-80049
- FlashPro Manager version (not 'the latest') 1.3.7.0
- the calibration (as an attachment) => provided EU-CRZ stock equivalent not modified
- a datalog of a problem (as an attachment) =>
- what sort of vehicle you have => European CR-Z
- what sort of ECU you are using => stock ECU
- anything about the car which has been modified from stock which may affect the ECU (don't include what sort of rims you have nor stereo etc).
=> engine related bolt on list :
HKS RSR intake (red 2 layer wet filter element)
Spoon Throttle Body
T1R exhaust
Spoon muffler
GE8 intake manifold plenum
motul 0w20 300v racing oil / mugen oil filter element
- a specific description of the problem
I did my first datalog in order to start calibrate the AFM sensor, from graph view, i decided to increase AFM flow numbers by 6%
i clicked on mass flow (g/s) row header button in order to select all row
i go to Edit menu, select Adjust
boom! - Abnormal program termination
computer is : Toshiba Satellite C660D-1C6
windows 7 Home Prem.
edit : i am not a windows guy, this PC has nothing else installed than Flash Pro managed and needed stuff.
Team CR-Z Youtube Videos here => http://www.youtube.com/playlist?list=PL127E8C02C6B25D4B&feature=plcp
CR-Z GT White "Blue Inside"
alollini
Re: FlashPro Manager 1370 crash
Post by alollini »
the Edit menu commands are making the crash,
however by right clicking on the selected items to adjust values works !
Start by downloading the most recent Beta version of software and see if that resolves the problem.
alollini
Post by alollini »
Thanks I will try that.
Thanks for the report - the problem is still there in 1.4.2; I will fix very shortly.
