Tuning for E85
Posted: Fri Dec 07, 2012 8:00 pm
For anyone out there having problems getting a decent map on E85, here is what I found. Make sure that if you go 30% across the normal fuel tables you don't go past 100 percent on your injector duty cycle, and make sure you have your injector dead times exactly what the manufacturer has specs on. I had to update to the newest Smanager because the previous version wouldn't let me enter the closest exact voltage value coinciding with the milliseconds. I had to find this out myself. Also 2 degrees advanced across the board up to 7 once you get it on the dyno.
