S300 check engine light no codes?
Posted: Thu Dec 06, 2012 9:03 pm
by Shmoke91
I have a 93 prelude and ever since I started using hondata I get random check engine lights that don't have codes but it affects the drive ability drastically when I try to clear the codes to turn off the light it doesn't work I have to remove the s300 chip and put it back in to clear the code I have tried another chipped ecu it worked good for a few months then right back to the cel light I'm at my wits end do I give up on hondata or what? I need these fake cel to go away hondata is a great product I've just had so many problems I just want my car to run without this fake cel. I also have USB connectivity issues doesn't always work?
I have the latest software installed
Re: S300 check engine light no codes?
Posted: Fri Dec 07, 2012 10:26 am
What is the serial number of the s300 inside the ECU and who sockedted your ECU? What spark plugs are you using?
Posted: Fri Dec 07, 2012 12:47 pm
by Shmoke91
Hondata serial number:#s300-1146
I bought my two ecus Pre socketed at jotech Motorsports in garland tx.
And as for plugs I'm running ngk 2262.
There is a sticker in my ecu that the number is 0635889 this is a white sticker with red letters
Posted: Fri Dec 07, 2012 1:00 pm
Are those plugs resistor or non-resisitor type?
Posted: Fri Dec 07, 2012 1:18 pm
by Shmoke91
I don't know but they are the stock plugs for a civic
Posted: Fri Dec 07, 2012 1:24 pm
by Shmoke91
Resistors for sure just googled it
Posted: Mon Dec 10, 2012 10:17 am
From Help, about, what version of software are you using? When did you purchase this s300?
Posted: Mon Dec 10, 2012 11:51 am
by Shmoke91
Version 2.1.1.0
And I bought this shortly after y'all released them I'd say I've had it since 05 or so
Posted: Mon Dec 10, 2012 4:06 pm
Send an email to support <at> hondata.com with the following and I will issue an RMA and give you further
instructions (include a link to this thread):
Name:
Address:
Phone:
Email:
Serial#:
Description of Problem:
Posted: Tue Dec 11, 2012 8:59 pm
by Shmoke91
Cool will do thank you for the help.
