Prb ecu and Closed loop question
contectr
Post by contectr »
Hi Hondata,
i'm ready to swap a Honda K20 engine turbo on my Lotus exige car.
The question is for the ecu..
with the PRB ecu and the wideband OEM Rsx-s sensor and engine harness, the ecu can handle a closed loop target for load value on boosted application?!(For example over 3 psi 12.50 afr and over 9 psi 12.00 afr)
Honda Ep3 stock k20a2 jrsc
Re: Prb ecu and Closed loop question
You could increase the closed loop max MAP and set the WOT compensation tables, but this is not something the ECU is designed to do.
