From 750cc to 1000cc
Posted: Sun Nov 25, 2012 12:42 pm
by Steeve_Civic
I would like to change my injectors to 1000cc.
Is there somewhere in S300 to adapt the map please?
Re: From 750cc to 1000cc
Posted: Mon Nov 26, 2012 10:35 am
Parameters, Fuel Trim.
Posted: Mon Nov 26, 2012 1:09 pm
by Steeve_Civic
OK but that doesn't change the fuel tables numbers ??
Posted: Mon Nov 26, 2012 1:45 pm
fuel trim changes do not change the table values
Posted: Mon Nov 26, 2012 3:04 pm
by Steeve_Civic
ok I will try, but still do not understand.
Could you explain me why it doen't change the fuel table? Fuel table isn't the injector opening time?
Posted: Sat Dec 01, 2012 1:56 am
by Steeve_Civic
Do you know the explications?
Posted: Sat Dec 01, 2012 10:36 pm
by mtber
Steeve_Civic wrote:ok I will try, but still do not understand.
Changing the injector size will change the fuel multiplier & leave the fuel table values the same.
The easiest explanation is that the software uses this to calculate how much fuel to inject on all of the global fuel values.
To learn how to adjust your injector fuel trims read:
http://www.hondata.com/help/smanager/in ... eltrim.htm
http://www.phearable.net
