2009 S2000 ABS wiring diagram
Posted: Wed Nov 21, 2012 10:01 am
by RR-racing
Two questions regarding installation on my 2009 S2k:
(1) Can you post ABS wiring diagram for the AP2 cars? I can't find it anywhere, other than by paying for a Honda shop manual, which would be rediculous.
(2) Is there a tool/method for removal of the ABS wire harness from the ABS module. I seems to have some white clips that keep in place, please advise.
thanks.
Re: 2009 S2000 ABS wiring diagram
Posted: Wed Nov 21, 2012 10:52 am
Our manual that comes with the traction controls states that the 06-09 S2000 has active ABS sensors, but this incorrect. They are passive.
The manual has the pinout and wire colors for the 06-09 S2000 listed in the manual.
There is a release tha must be pushed down in front of the orange lever, then you pull the lever down.
Posted: Wed Nov 21, 2012 11:12 am
by RR-racing
Spunkster wrote:Our manual that comes with the traction controls states that the 06-09 S2000 has active ABS sensors, but this incorrect. They are passive.
Ok, thanks i found the wiring in the manual.
Regarding removal of the harness, the orange lever just removes the cover, how do you unclip the entire connector (otherwise its really difficult to work the wiring).
Regarding the ABS type, I just want to verify that you are saying it should be wired in parallel?
thanks.
Posted: Wed Nov 21, 2012 11:25 am
Wire it for inductive sensors.
Once the lever on the harness is pulled down it will be unplugged and can be pulled away from teh ABS unit.
Posted: Fri Nov 23, 2012 4:53 am
by RR-racing
OK, the key here is the release to push the orange lever down... if you didn't know its there (it is not readily visable), you would be guessing for a long time how to get the orange lever down.
