FMU/FPR help - also missing link
angela_itr
Post by angela_itr »
Hi guys,
I've just had a Drag 3 turbo kit installed on my ITR, running RC 440cc injectors, a Walbro 255lph in-tank fuel pump, and Hondata s200 with stock internals. I'm looking to run 230-240hp initially.
The kit came with a boost dependant FMU fuel regulator - am I right in thinking this is no longer necessary with the Hondata, and should be removed? If so, do I need a replacement fuel pressure regulator or will the stock one be sufficient?
I've been getting confused with the difference between FMUs and FPRs, and which is good/bad :? If I need an FPR, can someone recommend a good one that comes with a gauge? I've seen the B&M ones but read that they aren't adjustable?
Also I've had a missing link fitted as it came with the kit. Again, should I remove this? I read something about problems with a missing link and Hondata but didn't really understand.
Sorry for all the questions :oops: just there's not many people in the UK who have gone the turbo route so its hard to get good advice.
Cheers :)
Angela
DaX
Post by DaX »
The S200B will replace the need for an FMU. An FMU is a "rising rate regulator." For instance, if you have a 12:1 FMU, for every psi of boost, the FMU adds 12psi of fuel pressure. When using Hondata, you need a 1:1 Fuel pressure reuglator. The stock regulator is 1:1 and should work fine up to a certain point, as it can become restrictive in higher horsepower applications. The B&M unit only modifies the stock FPR to allow it to become adjustable [so yes, the B&M is adjustable]. I currently have one. You can adjust the fuel pressure with it, but you can only increase fuel pressure above static fuel pressure...for instance if running a stock pump, you can't turn the fuel pressure down below about 38psi with the B&M unit. AEM makes one that is decent I think. IMHO, the best is Aeromotive. I know the Aeromotive FPR is fully adjustable.
Sell the missing link when you sell the FMU. The missing link fools the MAP sensor into not seeing boost [it's a one way valve...it only allows the MAP sensor to read vacuum]. Hondata requires that the MAP see boost, because now with Hondata, the ECU can interpret boost and adjust fuel and ignition accordingly.
angela_itr
Thanks Dax, things are a whole lot clearer now :)
