Starting car for first time, but won't start
dawson
Post by dawson »
My car will not start..., it cranks over and trys to start but won't. My O2 sensor is not hookup to my exhaust, and i have 450 dsm injectors. i hear all this stuff about the injectors, and am guessing this is the problem. I am wondering how out there is running with the dsm injectors and what problems they have
dawson
Post by dawson »
alirght i blieve it is becuase of my injectors. I read the post about the dsm 450's (which i am running) has anyone ever experienced this problem?
DaX
Post by DaX »
Remember to keep it simple. A car only needs four things to run [really 5 if you count timing].
Spark - Make sure you are getting a good spark on all of your cylinders. I throw timing under this, because it's spark related, but also make sure your mechanical and electrical timing are set correctly.
Fuel - Make sure you are getting fuel. Check to see if the fuel pump is running. Make sure your injectors are firing.
Compression - Is this a new build? Do you think you may have washed the cylinders?
Air - This is usually never the problem, but make sure there is nothing blocking the intake tract.
Boofster
Post by Boofster »
You need a basemap. Contact your Hondata dealer or tuner.
Da Boost
