is the idle mixture adjustable?
j2bates
Post by j2bates »
when the car is idling in closed loop is the fuel being injected and the timing settings based on the calibration loaded or is it a different map?
i'm getting misfire codes (all cylinders) and the engine shakes slightly, it also has an intermittant "thump" through the exhaust.
greddy turbo,intercooler,rc 440's,k-pro(rev hard 440 calibration) ngk vpower with 7 heat range
silum
Post by silum »
It uses the standard tables plus the long term O2 corection and constanty adjsuts based on the short term O2 calculations.
So after some period of time at the same RPM in closed loop your fueling should be fine. Make sure your maps are very close to perfect around the idle area. Otherwise your long term O2 correction will get out of hand and affect the rest of the map even when in open loop.
You can play with the timing and idle rpm to see if you can fix the misfire. Make sure your plugs aren't foweled too.
Hondata Stage 4BD
USDM 1995 Civic Si (EH)
D16Z6, 1.6L SOHC VTEC
Apex-i BB AX Turbo w/ GT I/C & AVC-R II
440cc RC Injectors
Walbro 255LPH HP Pump
B&M Command-Flo
Jun UltraLW Flywheel
ACT Clutch
Quaife LSD
SRP Pistons (Stock C/R)
Crower Rods
