Metric Gauges Displays
Posted: Mon Nov 12, 2012 2:16 pm
by Steeve_Civic
All your displays are in Farhenheit and PSI.
I use Metric (BAr and Celcius) how can I change displays please?
Thks
Re: Metric Gauges Displays
Posted: Mon Nov 12, 2012 3:28 pm
select the gauge you want to change, right click and you can change the caption. You will also have to change the units in Options, Settings amd in the sensor window.
Posted: Tue Nov 13, 2012 4:47 am
by Steeve_Civic
Thank you, just changed the caption.
Moreover I need also to change the value min and max otherwise I still have numbers in PSI?
Posted: Wed Nov 14, 2012 11:07 am
you will have to change all parameters associated with the units you want to change.
Posted: Wed Nov 14, 2012 11:37 am
by Steeve_Civic
OK
I need to change in Options-Sensors and options-Setting-Units then change on the gauge with a right click correct?
Posted: Wed Nov 14, 2012 12:18 pm
correct
